Document the whole home in minutes: iGuide Express Sketch for restoration and claims
iGuide Express Sketch pairs an AI-generated virtual walkthrough with an Xactimate sketch (ESX), delivered in minutes. One order also gives you a floor plan with fixtures, PDFs and room volume.
You need the whole home documented, and you need it fast. iGuide Express Sketch combines an AI-generated virtual walkthrough with an Xactimate Sketch (ESX), delivered within minutes. It also gives your crew a floor plan they can work from on site and the documents your office and adjusters need, all in one order.
What slows a restoration job down
Manual floor plan sketching
Documenting a home by hand takes time. Measuring each room, drawing the layout and capturing photos can take hours, and the job on site can’t wait. Every minute spent sketching is a minute not spent mitigating damage.
Inaccuracies and errors in traditional floor plan sketching
When measurements and sketches are done by hand, mistakes happen. A wrong measurement can delay a claim or lead to the wrong amount of equipment on a job. When the sketch doesn’t match the home, it causes misunderstandings between contractors, adjusters and homeowners.
One workflow, no new tools
Crews need a fast way to document the whole home, map the job and pass the information on, without changing the tools their estimators already use.
What is iGuide Express Sketch?
iGuide Express Sketch is an AI-generated virtual walkthrough and Xactimate Sketch for residential restoration and mitigation work. It’s well suited to homes affected by water damage, storms and limited fire damage.
Every Express Sketch includes:
- An ESX file for Verisk Xactimate, downloaded from the iGuide Portal
- A 3D virtual walkthrough with an interactive floor plan
- Fixtures (toilets, sinks, tubs and similar) placed on the floor plan
- A Floorplan PDF and a Tag Report PDF
- Room dimensions and room volume for every room
- Rooms and Openings CSVs in metric and imperial
- Real-Time Tagging of key features on site
- No scan limit
Express Sketch is $29.99 USD per order, whatever the size of the home. Offline ZIP is available as an add-on.
How does iGuide Express Sketch work?
iGuide uses optical imaging, laser (Lidar) measurements and AI drafting to document the home. Scan the home with the PLANIX camera, upload to the iGuide Portal and choose Express Sketch on the Create page. Within minutes, your walkthrough, floor plan, PDFs and ESX are ready to download from the iGuide Portal.
Work smarter, not harder
Scan the whole home
There’s no scan limit, so a large or multi-level home is still one walkthrough and one flat price.
Map the job on the floor plan
Fixtures are placed on the floor plan, so the person who scanned the home can mark where air movers and dehumidifiers are set. Room volume for every room helps when sizing drying equipment.
Keep your Xactimate workflow
Your estimator gets the same ESX they already use, downloaded from the iGuide Portal. The Rooms and Openings CSVs are there when you need the numbers.
Everyone sees the same home
Express Sketch gives everyone on the job the same view of the home. Share the virtual walkthrough with adjusters and homeowners. Mark up the Floorplan PDF and Tag Report PDF and send them on to your office or the carrier. Fewer return visits, fewer phone calls and fewer misunderstandings about what’s in the home.
Which iGuide sketch package is right for the job?
Express Sketch is built for homes. For commercial jobs or large losses, iGuide Standard Sketch and Premium Sketch are drafted by professional drafters and include more detail in the ESX. Premium Sketch adds cabinets, complex ceilings, fixtures in the ESX and more. Learn more in iGuide Sketch Packages, or see the full iGuide for Insurance overview.
Coming from Instant Sketch?
iGuide Express Sketch replaced iGuide Instant Sketch on November 24, 2026. If Instant Sketch was your default package, your account now uses Express Sketch. Instant Sketch iGuides created before then keep their files and ESX.
One order. The whole home documented.
See what’s in an Express Sketch, or book a 20-minute demo to see how it cuts repeat visits and keeps your estimator in Xactimate.
Frequently asked questions about iGuide Express Sketch
How much does iGuide Express Sketch cost?
Express Sketch is a flat $29.99 USD per order, no matter the size of the home. There are no per-square-foot charges and no scan limit, so a large or multi-level property costs the same as a small one. Offline ZIP is available as an add-on.
Is iGuide Express Sketch suitable for fire damage jobs?
Express Sketch works well for homes affected by water damage, storms and limited fire damage. For heavy fire losses, commercial jobs or large losses that need more detail in the ESX, iGuide Standard Sketch or Premium Sketch, drafted by professional drafters, are the better fit.
Do I need special hardware to create an Express Sketch?
Yes. You scan the home with the PLANIX camera, then upload the files to the iGuide Portal and choose Express Sketch on the Create page. Within minutes your virtual walkthrough, floor plan, PDFs and ESX file are ready to download from the Portal.
What is the difference between Express, Standard and Premium Sketch?
Express Sketch is AI-generated and built for homes. Standard Sketch and Premium Sketch are drafted by professional drafters and carry more detail in the ESX, with Premium adding cabinets, complex ceilings and fixtures. You can upgrade a job when it needs that extra detail.
Will my estimator still receive an ESX file for Xactimate?
Yes. Every Express Sketch includes an ESX file for Verisk Xactimate, downloaded from the iGuide Portal, so your estimator keeps the workflow they already use. Rooms and Openings CSVs in metric and imperial are included when you need the raw numbers.
Accurate compared to what? Accuracy vs precision for floor plans
Accuracy is how close a measurement is to the truth. Precision is how consistent it is. No measurement is exact, so the real question is how far off a number might be. Here’s what that means for floor plans and four questions to ask before you trust any measurement.
Day one only happens once. Capture all of it.
A pipe bursts on a Friday night. Your after-hours crew arrives within the hour, documents the damage, begins extracting water and sets drying equipment in place. Before the job changes, you need a complete record of what the property looked like on day one. That's where iGuide comes in. One capture session produces the 360 virtual tour, room photos, damage tags and estimate-ready sketch that become the foundation of the claim.
