iGuide vs Matterport, CubiCasa and Asteroom: which tool is right for you?
Choosing between iGuide, Matterport, CubiCasa and Asteroom isn’t really about features. It’s about how each tool fits into your workflow. Because what looks good on paper doesn’t always hold up when you’re on-site, managing multiple shoots or trying to scale your business.
Before comparing platforms, it helps to get clear on what actually matters day-to-day.
Most photographers aren’t choosing between tools based on features. They’re choosing based on how those tools affect their time, output and margins.
Here’s what tends to matter most:
- Accuracy: can you trust the floor plans and measurements? Or are you double-checking and second-guessing your deliverables?
- Time on site: how long does it take to capture a property and how many jobs can you realistically do in a day?
- Outputs: what do you actually get from one job? Just a tour, or a full set of deliverables you can hand off with confidence?
- Pricing predictability: not just what it costs, but whether pricing stays consistent as you grow your business.
These four things determine how fast you work, how much you earn and how much friction you deal with day-to-day.
iGuide vs Matterport, CubiCasa and Asteroom: quick comparison
How this plays out at scale
With Matterport, we went over our monthly limit by 4,000 scans. The hosting fees and penalties were ridiculous. And no one even flagged it.— Glen MacIsaac, Photography Manager, Royal LePage Atlantic
That’s the difference between subscription-based pricing and predictable per-project pricing. At small scale, it’s manageable. At volume, it becomes a real cost risk.
iGuide vs Matterport: accuracy, speed and control vs visual-first tours
Matterport is known for immersive 3D tours. And if that’s your priority, it delivers.
But once you look beyond the visuals, the differences start to show up in workflow, accuracy, and cost control.
Spend less time on site
Matterport uses a scan-by-scan workflow. iGuide uses a single-pass capture. That difference adds up quickly.
Matterport takes 45 minutes to an hour per house… The 3,000-square-feet I can do with iGuide in less than 30 minutes.— Nima Mohammadi, Nima Mohammadi Photography
More speed on site means more properties per day and less burnout.
Measurements you can actually rely on
iGuide provides published accuracy standards (±0.5% / ±1%).
With Matterport, measurement accuracy isn’t publicly specified in the same way.
Accurate measurements are what prevent callbacks, corrections and client friction. They’re also what makes your deliverables usable beyond just marketing. If you’re working with agents, appraisers or contractors, that distinction matters.
Everything from a single capture
With iGuide, one capture delivers:
- Floor plans
- 3D tour
- Measurements
- Property data
You’re not piecing together multiple tools or outputs. That means fewer handoffs, less waiting and faster delivery to your clients.
And faster delivery frees you up to move on to the next job.
Pricing that grows with your business
Matterport operates on subscriptions and hosting fees.
That can mean:
- Overage charges
- Ongoing hosting costs
- Limited control over your data
iGuide uses a pay-per-project model, with no hosting fees and full data ownership . That gives you more control as your business grows. Costs stay tied to the work you’re actually doing.
When Matterport may still be a fit
Matterport can make sense if:
- You’re focused purely on visual tours
- You’re okay with subscription pricing
- Accurate measurements aren’t essential for your workflow
Quick takeaway:If your work depends on accuracy, efficiency and predictable costs, iGuide is the stronger fit. If visuals are your only priority, Matterport may still work. Want a deeper breakdown? See our full iGuide vs Matterport comparison.
iGuide vs CubiCasa: mobile simplicity vs full property data
This comparison comes down to simplicity vs depth.
Where it makes sense
- Mobile-based capture
- Fast, simple floor plans
- Low barrier to entry
For quick, lightweight use cases, that’s often enough.
Where iGuide adds more depth
- Higher measurement accuracy
- Floor plans, 3D tours and property data from one capture
- A more reliable workflow for professional use
If your work requires consistency and detail, not just speed, that difference starts to matter.
Quick takeaway: CubiCasa works for quick floor plans. iGuide is built for full property documentation and professional use. For a closer look, see how iGuide compares to CubiCasa in more detail.
iGuide vs Asteroom: budget-friendly tours vs complete deliverables
Asteroom is a solid entry point for 3D tours:
- Lower-cost option
- Quick turnaround
- Easy to get started
As with CubiCasa, the gap shows up in depth and reliability:
- Measurement accuracy you can stand behind
- Floor plans and structured property data included
- More consistent outputs for client-facing work
Whether you’re shooting residential or commercial, the expectation is the same: clean deliverables, accurate data and fast turnaround.
Quick takeaway: Asteroom is a budget-friendly option for basic tours. iGuide is built for photographers who need complete, reliable deliverables.
Which tool should you choose based on your workflow?
If you strip everything back, the decision is pretty straightforward.
Choose iGuide if you need:
- Multiple deliverables from one capture
- Predictable pricing as you grow your business
Choose Matterport if:
- Visual tours are your main priority
Choose CubiCasa if:
- You only need basic floor plans
Choose Asteroom if:
- You want a low-cost 3D tour option
Choose based on accuracy, workflow and output needs
Every tool here has a place.
But once you move beyond a single listing and start thinking about consistency, scale, and the kind of work you want to be known for, the decision becomes clearer.
- Can you trust the data?
- How fast can you work?
- What do you deliver at the end of each job?
If those things matter to your business, the right choice is the one that holds up in real-world use.
👉 See how iGuide fits into your workflow. Book a demo
Is iGuide more accurate than Matterport?
iGuide publishes measurement accuracy standards (±0.5% / ±1%), while Matterport does not publicly specify accuracy in the same way.
Does iGuide require a subscription?
No. iGuide uses pay-per-project pricing with no ongoing hosting fees.
What outputs does iGuide provide?
iGuide provides floor plans, a 3D tour, measurements and complete property data from a single capture.
Which tool is best for real estate photographers?
The best tool depends on your workflow, but most real estate photographers prioritize accuracy, speed and predictable pricing. iGuide tends to stand out in those areas.
How to hire a real estate photographer: what to ask for beyond the photos
A complete listing needs photos, an accurate floor plan, measurements and a virtual tour. An iGUIDE Pro delivers all four in one visit and one report.
Victoria just gave agents a new reason to call you
From October 2026, real estate agents in Victoria must publish internal floor area in square metres on residential listings, with auctions and fixed-date sales following from 16 October.
