If a project won't upload from the PLANIX app, you can upload its Stitch file directly through your device's browser instead. This article covers browser uploads and how to reduce failed scans and missing data during export.
- Uploading a Project via Smart Device Browser
- Troubleshooting
- Turn off the PLANIX R1 and connect your device to reliable Wi-Fi.
- Open a browser and go to manage.youriguide.com.
- Sign in and select + Create iGuide.
- Enter the property details (industry, package, add-ons, address).
- Click the Drag and drop exported Stitch TAR box.
- Go to PLANIX → [project folder] → _Export and select stitch.tar.
- Click Create iGuide to start the upload.
Important: Do not switch apps or let the screen turn off until the upload reaches 100%.
For other upload options, see How to Upload Projects with the R1.
Failed scans or missing data during export
If a scan fails and the image doesn't fully transfer to your device, the PLANIX app will notify you and let you retake the scan.
To reduce the chance of failed scans:
- Use the 5 GHz Wi-Fi band when available.
- Keep your PLANIX R1 updated with the latest firmware. See How to Update the R1 & Theta Firmware.
- Stay close to the camera during scans.
- Avoid older or unsupported smart devices.
If uploads keep failing, contact iGuide Support and attach your logs — see Submitting R1 Logs for Support.
Q: Which Wi-Fi band should I use with the PLANIX R1?
A: Use 5 GHz when available to reduce failed scans. If the camera disconnects unexpectedly, try switching between 2.4 GHz and 5 GHz. See R1 Wi-Fi & Connection Troubleshooting.
Q: Which phones and tablets can I use with the PLANIX app?
A: The PLANIX app is available for iOS and Android. iPhone requires iOS 15.8 or later, and iPad requires iPadOS 15.8 or later. Download the app from the Apple App Store or Google Play Store. See How to Download the PLANIX App.
Q: What should I include when I contact iGuide Support?
A: Include your phone's make and model, the camera's serial number, what the app showed when the problem happened, and your PLANIX app and camera logs. The more information we have, the quicker we can help!
