This article covers what to do if you can't connect to the PLANIX R1 or it keeps disconnecting. Work through the steps in order to get your camera connected and capturing again quickly. Most connection issues are fixed in Step 1.
- Before You Begin
- Step 1: Restart Your Devices and Check Your Settings
- Step 2: Test with a Different Mobile Device
- Step 3: Reset the PLANIX R1's Wi-Fi
- Step 4: Forget and Reconnect the Camera
- Troubleshooting
These steps are for a camera that has been set up before. For first-time setup, see How to Connect to the R1.
- Power off the PLANIX R1, wait, then power it back on. Restart your phone or tablet as well.
- Turn on Airplane Mode, then turn Wi-Fi back on. Keep Airplane Mode active while you reconnect.
- Turn off mobile/cellular data if your device allows it. This stops your device from switching networks.
- Turn off any active VPN. VPNs can interfere with the connection.
- If the camera connects but disconnects unexpectedly, switch Wi-Fi bands (2.4 GHz ↔ 5 GHz). See Survey Settings.
Open the PLANIX app and try connecting again.
If the PLANIX R1 still won't connect, test it with another phone or tablet. This tells you whether the problem is with the camera or your device.
- Install the PLANIX app on a second phone or tablet and sign in.
- Connect the PLANIX R1 from the second device.
- If it connects, the problem is likely with your original device's settings, OS version or hardware. Check that the device is supported and up to date.
- If it still won't connect, continue to Step 3.
- On the right side of the camera, press and hold the 0 and M buttons together for 5 seconds.
- Press the camera button below the LCD display.
- Restart Wi-Fi by pressing the Wi-Fi button on the top left.
- On your mobile device, confirm the camera's SSID (shown on the QR code screen) is broadcasting.
- Reconnect to the camera.
If you still can't connect, remove the camera completely and add it again.
- Open your device's Wi-Fi settings and forget the PLANIX network.
- In the PLANIX app, go to Devices → tap the three dots → Delete.
- Power off the PLANIX R1, wait, then power it on again.
- Reconnect the camera as a new device.
Note: Do not delete the PLANIX app. All project data will be lost.
Camera connection error on some Android phones (Xiaomi 17)
Some Android phones, including the Xiaomi 17, can't connect to the PLANIX R1 through the app while the phone is on a 6 GHz Wi-Fi network and the camera is on 5 GHz. You may see a Camera connection error, or the app keeps asking you to reconnect even after you tap Retry or scan the QR code again. Your camera is working normally. The problem comes from the phone.
Use any one of these fixes:
- Connect manually: On your phone, go to Settings → Wi-Fi, choose the camera's network (e.g., PLANIX-XXXXXXXX.osc) and enter the password from the camera's base label. Then go back to the PLANIX app. See Manual Connection Method.
- Disconnect from other Wi-Fi first: In Settings → Wi-Fi, disconnect from your home or office network, then connect to the camera in the app.
- Switch the camera to 2.4 GHz: See Step 1 above.
Frequent connection issues
If your PLANIX R1 won't connect or keeps disconnecting, the Theta firmware on your camera may be out of date. Cameras built in 2024 and 2025 shipped with Theta firmware 2.62.1, and plugin 1.7.0 needs Theta firmware 2.80.2 or later to connect reliably. Your camera is working normally. It just needs the Theta update.
- Check your camera's Theta firmware version.
- If it's older than 2.80.2, update the Theta firmware. See How to Update the R1 & Theta Firmware.
- Restart the camera and reconnect in the PLANIX app.
If you're still having trouble, contact iGuide Support. Include your phone's make and model, the camera's serial number, its Theta firmware version, and what the app showed when it failed. Attaching logs helps too — see Submitting R1 Logs for Support.
Q: Should I delete and reinstall the PLANIX app to fix a connection problem?
A: No. Deleting the PLANIX app erases all project data. Instead, forget the PLANIX network and reconnect the camera as a new device (Step 4 above).
Q: Which Wi-Fi band should I use with the PLANIX R1?
A: Use 5 GHz when available to reduce failed scans. If the camera disconnects unexpectedly, try switching between 2.4 GHz and 5 GHz. On some Android phones, such as the Xiaomi 17, switching the camera to 2.4 GHz fixes connection errors.
Q: How do I switch the PLANIX R1 between 2.4 GHz and 5 GHz?
A: Connect to your camera in the PLANIX app and open Survey. Tap the hamburger menu in the top-left corner, select Settings, then under Camera Settings choose a Wi-Fi Band. 2.4 GHz gives better range and 5 GHz gives better performance. See Survey Settings.
Q: Which phones and tablets can I use with the PLANIX app?
A: The PLANIX app is available for iOS and Android. iPhone requires iOS 15.8 or later, and iPad requires iPadOS 15.8 or later. Download the app from the Apple App Store or Google Play Store. See How to Download the PLANIX App.
Q: My R1 keeps disconnecting even after all the troubleshooting steps. What now?
A: Your R1 may be running older firmware. Update it and reconnect. See How to Update the R1 & Theta Firmware.
Q: What should I include when I contact iGuide Support?
A: Include your phone's make and model, the camera's serial number, what the app showed when the problem happened, and your PLANIX app and camera logs. The more information we have, the quicker we can help!
