The PLANIX R1 is iGuide's all-in-one camera system used to capture 360-degree visuals and lidar measurements for property tours and floor plans. Each unit ships as a complete kit, including the camera body, battery, charging accessories and protective gear, so operators have everything required to start scanning.
This guide outlines what's included with the R1, where to find manuals and tech specs, and answers to common questions about battery handling and the integrated Theta X camera.
- What is included in purchasing a R1 Camera Unit?
- R1 Camera Manual & Specs
- Important Notes
What's Included With an R1 Camera Unit
- PLANIX R1 camera system
- Soft carrying case with a shoulder strap
- System shield
- Protective neoprene sleeve
- R1 battery with battery cover
- Battery charger
- USB power supply
- USB-C cable
R1 Camera Unit Manual & Specs
PLANIX R1 Manual
PLANIX R1 Quick Start Guide
PLANIX R1 Tech Specs
- Always charge the R1 using the original USB-C cable and power supply that came with the camera. Using different cables or power supplies may prevent the battery from charging.
- Battery Storage & Maintenance: To help maximize battery life and performance, charge all batteries fully upon receipt. If a battery will not be used regularly, we recommend recharging it at least once every 4 months. Batteries stored at very low charge levels for extended periods may become depleted below the safe charging threshold and may no longer be recognized by the charger.
Q: Can I hot swap the R1 Battery?
A:
While the R1 features a quick-release battery, it cannot be hot-swapped (i.e. replaced while the system is powered on). To change the R1 battery you must turn off the system first before switching the battery.
Q: How will I know when the R1 battery is running low?
A:
The battery icon in Survey changes as the battery runs down:
- Below 20%: The battery icon turns red and shows one bar.
- Below 10%: No bars, and the icon blinks red.
- Below 1%: A notice says the camera will shut down in 10 seconds, and then it shuts down automatically.
When the icon turns red, finish your current scan, turn off the R1, and swap in a charged battery.
Q: Can I use the Theta X on the R1 independently?
A:
For the PLANIX Pro, the Theta Z1 could be detached from the system unit and used as a standalone camera with the Ricoh Theta app. However, with the PLANIX R1, the Theta X is fully integrated into the system. It is neither user-replaceable nor removable. If a replacement is needed, please send the system to us for servicing by opening a support ticket.
