This article covers physical PLANIX R1 issues you can fix in the field: a battery that won't charge, compass calibration that fails, North that's incorrect on a published iGuide, and not hearing the second tone after a scan.
- Battery Not Charging
- R1 Compass Calibration
- North Is Incorrect on a Published iGuide
- Troubleshooting
If your battery shows a blinking red light, a solid red light, or no light at all while charging, try the following:
- Use the original charger (USB cable and power block) supplied with the PLANIX R1.
- Confirm the battery isn't already fully charged by inserting it into the PLANIX R1.
- Push the battery firmly into the charger until it clicks.
- If the charger's metal pins sit too far back, gently pull them forward (see image below).
- If the battery's metal contacts look recessed, lift them outward.
If charging still fails, contact iGuide Support.
You calibrate the R1 with a simple hand motion while the PLANIX app is open.
- Hold the camera upright in your hand.
- Move it in a figure-8 motion until the compass icon turns grey. A grey icon means calibration is complete.
For more detail, see PLANIX Camera Compass Calibration.
If calibration won't complete:
- Move away from metal doors, frames, garages, factories, or magnets.
- Power the camera off and on, then try again.
Note: A failed calibration doesn't block your scan. The project will still work normally.
You can adjust the compass angle in the iGuide Portal. See Customizing the 3D Tour From the iGuide Portal.
Not hearing the second tone after a scan
If you hear the first beep but not the second "duh-doo" tone, Noise Reduction is probably on. With Noise Reduction enabled, the second tone is silent. This is normal.
To hear both tones, set HDR mode, turn off Noise Reduction, and make sure your phone volume is up. See R1 Camera Settings for where to find these settings, and How to Use the R1 Camera for what each tone means.
Q: Will a failed compass calibration stop my project?
A: No. You can still capture, upload and publish your iGuide. North may need to be corrected afterward in the iGuide Portal.
Q: How do I find my camera's serial number?
A: The serial number is on the bottom of your camera and begins with R1. You can also find it in the PLANIX app: connect to your camera, open Survey, tap the hamburger menu, select Settings and scroll to the bottom. See Survey Settings.
Q: What should I include when I contact iGuide Support?
A: Include your phone's make and model, the camera's serial number, what the app showed when the problem happened, and your PLANIX app and camera logs. The more information we have, the quicker we can help!
