Submitting R1 Logs for Support
When you contact iGuide Support about an R1 issue, attaching logs helps the team find the cause faster. There are two kinds: app logs from the PLANIX app and camera logs from the R1 itself. If you're not sure which one Support needs, send both.
How to Submit PLANIX App Logs
  1. Disconnect the R1 from your device and open the PLANIX app.
  2. Tap Settings in the bottom-right corner.
  3. Scroll down and tap the upload icon beside Share logs to Support team.
  4. Save the file to your preferred location. Then share it via SharePoint or Google Drive, or attach it to a support ticket.
How to Submit Camera Logs
  1. Turn on the camera and confirm it appears under the Devices tab.
  2. Tap the three dots next to the camera and select Share Camera Logs.
  3. Wait for the log file to download.
  4. Attach the file to your support ticket.
Tip: In your ticket, include your phone's make and model, the camera's serial number, and a short description of what happened. You can also call iGuide Support toll-free at 1-855-505-1723 for hands-on help.
Q: What should I include when I contact iGuide Support?
A: Include your phone's make and model, the camera's serial number, what the app showed when the problem happened, and your PLANIX app and camera logs. The more information we have, the quicker we can help!
Q: How do I find my camera's serial number?
A: The serial number is on the bottom of your camera and begins with MS, MX or R1. You can also find it in the PLANIX app: connect to your camera, open Survey, tap the hamburger menu, select Settings and scroll to the bottom. See Survey Settings.
