This article explains how to capture irregular structures such as ships, yachts, sailboats, fishing boats, aeroplanes, private jets, trains and RVs. These projects are possible, but they have limits that you need to understand and explain to your client before you accept the job.
- Before You Begin
- How to Capture an Irregular Structure
- Troubleshooting
- The iGuide Drafting Standard follows the Alberta Residential Measurement Standard (RMS), which is based on ANSI Z765-2013 and extended to multi-family residential buildings. The RMS does not cover irregular structures.
- PLANIX cameras can capture these spaces, but the drafting standard doesn’t account for every structure type.
- We don’t refuse specific structure types. Past deliveries include ships, yachts, sailboats, fishing boats, aeroplanes and private jets.
- Larger and more complex vehicles need significantly more data, which also increases the risk of insufficient or misaligned scans.
Important: iGuide measurements for irregular structures are not RMS-compliant and can’t be relied on to the same degree as measurements for conventional buildings.
Step 1: Set client expectations
Before you start the project, explain to your client that:
- iGuides for irregular structures are not RMS-compliant.
- Measurements may be less reliable than those for conventional buildings.
- Delivery time depends on the size and complexity of the structure (see Step 5).
Step 2: Plan your camera placement
The height you scan at has a noticeable effect on the floor plan, so plan your camera placement carefully. Interior walls of boats and planes are often curved to match the exterior. Whenever possible, scan straight wall sections at the maximum width of the space.
Step 3: Capture the space
Follow the same scanning principles you use for buildings:
- Provide good lighting.
- Cover the full area.
- Keep the camera level.
- Keep laser scanner height clear of obstructions.
Note: Conditions on vehicles and vessels can make these principles harder to follow. High wind can disrupt scanning on a docked boat, and tight or cluttered spaces, such as a ship’s engine room, make it hard to keep laser scanner height clear.
Step 4: Align your data before you submit
Make sure your data is properly aligned before submission. We accommodate most requests when the data is properly aligned and of sufficient quantity and quality. We may refuse submissions that lack the data needed to produce a functional iGuide. See Aligning your Data in Stitch.
Step 5: Plan for delivery time
Deliverables for irregular structures look the same as those for regular buildings, but turnaround time varies. Expect delivery anywhere from same-day or next-day to several days, depending on size and complexity.
Standard projects are processed based on billable square footage, and properties near or above 10,000 sq ft can take multiple days. Irregular structures don’t follow this rule because of their unusual shapes.
Walls are curved: Scan straight wall sections at the maximum width of the space whenever possible.
Scans aren’t aligned: Make sure your data is properly aligned before you submit. See Aligning your Data in Stitch.
If the issue continues, please submit a support ticket. See iGuide Support Ticket Creation and Management.
Q: Can I create an iGuide of a yacht, plane, RV or other irregular structure?
A: Yes. However, these structures aren’t covered by the RMS, and measurements may not be as reliable as those for conventional buildings.
Q: Will you refuse my project because of the type of structure?
A: No. We don’t refuse specific structure types. We may refuse a submission if it lacks the data needed to produce a functional iGuide.
Q: Will the deliverables look different from a regular building?
A: No. Deliverables for irregular structures look the same as those for regular buildings.
Q: How long does an irregular structure take to deliver?
A: Anywhere from same-day or next-day to several days, depending on size and complexity. Billable square footage does not determine turnaround for these projects.
