Capturing Roof Plan
This article explains which scans you need to capture for a Roof Plan add-on. The scans depend on the roof type: flat roofs need horizontal rooftop scans, and pitched roofs need exterior scans.
  • The Roof Plan add-on requires the iGuide Premium base package.
  • Review the sample in Roof Plans (Pitched or Flat) so you know what the final deliverable looks like.
Scanning Requirements for Roof Plans
Flat roofs:
  • Capture horizontal scans of the rooftop.
  • Capture a scan at each rooftop access point.
  • No other scans are needed for flat roofs.
Note: Lower the camera system on the tripod, or remove it from the tripod, where needed.
Pitched roofs:
  • Don’t scan pitched roofs from the rooftop.
  • Capture exterior scans around the building to complete the add-on. Follow the Exterior Scan Guidelines in Horizontal and Vertical Scanning Techniques.
Note: These capture techniques are for add-ons on regular iGuide orders. To learn how to capture commercial and AEC projects, see the Advanced Capture Program.
Q: Do I need to go on the roof for a Roof Plan?
A: Only for flat roofs. Flat roofs need horizontal rooftop scans, including a scan at each access point. Pitched roofs use exterior scans instead.
Q: Can I add a Roof Plan to any iGuide package?
A: No. The Roof Plan add-on requires the iGuide Premium base package.
Q: Do I need to scan every rooftop access point?
A: Yes, for flat roofs. Capture a scan at each access point along with your horizontal rooftop scans.
Q: What if the roof's knee wall is shorter than the recommended height for capture?
A: You can place use the camera at a shorter height like on a tripod to capture a scan. The important detail is for Lidar data to be generated of the knee wall plus possible HVAC units.
