Some iGuide add-ons, including DWG Floor Plans, Reflected Ceiling Plans, Exterior Elevations, Roof Plans and 3D Models, require scan types and capture methods beyond a standard iGuide capture.
This article covers the two techniques these add-ons rely on, horizontal and vertical scanning, and links to the detailed capture requirements for each add-on.
- Add-on Scanning Techniques
- Horizontal Scanning
- Vertical Scanning
Capture Requirements by Add-on
Use the chart below to quickly identify which scan types are required for each add-on.
Review the article for each add-on for specific scan locations and capture instructions.
- Floor Plan (DWG): No special capture is required beyond a normal horizontal interior capture.
- Reflected Ceiling Plan Capture Requirements
- Exterior Elevations Capture Requirements
- Roof Plan Capture Requirements
- 3D Model Capture Requirements
- Capturing Irregular Structures (Boats, Planes, RVs)
Horizontal Scanning
Use horizontal scans to capture standard interior and exterior areas.
Important: When both exterior and interior scans are captured, capture the interior scans first. This allows the camera to align and calibrate the data.
Interior Scan Guidelines
- Entrances and exits: Capture 2 scans, approximately 3 ft (1 m) apart, with one on each side where possible.
- Room entrances and doorways: Capture 2 scans, one on each side where possible, approximately 3 ft (1 m) away.
- Windows: Capture 1 centred scan, approximately 5–10 ft (1.5–3 m) away, ensuring the window is fully visible.
- Rooms: Capture 2 scans from roughly opposite sides of the room. In larger rooms, add scans approximately every 10 ft (3 m) in a grid pattern.
- Staircases: Capture 1 scan at the top and 1 scan at the bottom.
- Mechanical and utility items: Capture 1–2 scans approximately 5 ft (1.5 m) away.
Watch the video below for an overview of recommended interior horizontal scanning techniques.
Exterior Scan Guidelines
Where exterior scans are required:
- Complete a loop around the building.
- Capture exterior scans approximately every 10–20 ft (3–6 m), as required for the deliverable.
- Capture a scan at every building corner, approximately 5 ft (1.5 m) from the corner.
- Capture a centred scan at each exterior window, approximately 5–10 ft (1.5–3 m) from the building face.
- Capture 1–2 scans of each exterior mechanical or utility item.
Complete Horizontal Coverage Example
Example: Recommended scan positions for complete property coverage.
Vertical Scanning
Vertical scans are optional for some deliverables and required or recommended for others.
Vertical Scan Guidelines
When vertical scans are required or recommended:
- Use a ball-head tripod.
- Position the camera at a 90° angle, creating an L-shape between the camera and tripod.
- Create a new floor for each set of vertical scans.
- Capture 2 vertical scans per room, where required.
- Capture an additional vertical scan at the highest point of the room.
- If a room has multiple high points, capture an additional scan below each high point.
Important: Hide or disable vertical scans in the project before submission.
Watch the video below for recommended camera positioning and vertical scanning techniques.
Vertical Scanning of Staircases
Where vertical stair scans are required:
- Capture 1 vertical scan at the top of the staircase.
- Capture 1 vertical scan at the bottom of the staircase.
- Capture vertical scans at stair landings as described in the applicable deliverable requirements.
Watch the video below for recommended vertical scanning techniques for staircases.
Vertical Scanning of Exteriors
Exterior vertical scans may be required or recommended for the Exterior Elevations and 3D Model add-ons.
Watch the video below for recommended exterior vertical scanning techniques.
Complete Vertical Coverage Example
Interested in becoming an Advanced Capture Pro?
The advanced capture techniques covered in this article are for capturing for add-ons on regular iGuide orders. If you're interested in expanding your skills to capture commercial and AEC projects, the Advanced Capture Pro program provides training on advanced capture requirements, deliverables, and workflows.
Q: Which base package do I need for advanced add-ons?
A: The DWG Floor Plan can be added to the iGuide Standard package (excluding Fixtures). The Reflected Ceiling Plan, Exterior Elevations, Roof Plan and 3D Model require the iGuide Premium package.
Q: Do I need vertical scans for every room?
A: No. Vertical scans depend on the deliverables being requested. They are required or recommended for certain deliverables, such as 3D Models, Reflected Ceiling Plans and Exterior Elevations. Review the requirements for the specific deliverable before capturing.
Q: What should I do with vertical scans before submission?
A: Create a new floor for each set of vertical scans before scanning. Hide or disable vertical scans in the project before submission.
Q: Should I scan the interior or exterior first?
A: Interior first. Capturing interior scans before exterior scans allows the camera to align and calibrate the data.
