Capturing Exterior Elevations
This article shows you how to capture the interior and exterior scans required for an Exterior Elevations order. Accurate elevation drawings depend on both horizontal and vertical scans, taken inside and outside the building.
These techniques are for capturing the Exterior Elevations add-on on regular iGuide orders. If you’re interested in capturing commercial and architecture, engineering and construction (AEC) projects, the Advanced Capture Pro program provides training on advanced capture requirements, deliverables and workflows. Learn about the Advanced Capture Program.
  • The Exterior Elevations add-on requires the iGuide Premium base package.
  • Review the Exterior Elevations sample to understand the expected final deliverable.
  • Be familiar with the standard horizontal scanning requirements in Horizontal and Vertical Scanning Techniques.
Important: Due to technical limitations, elevation drawings are typically limited to a maximum height of 2 storeys.
How to Capture Scans for Exterior Elevations
Step 1: Capture the interior horizontal scans
Capture the complete interior using the standard horizontal scanning requirements. Pay particular attention to every room that borders an exterior wall included in the elevation.
The lidar scanner measures these walls from the inside to capture window positions, door positions and other details. Exterior scans taken from a distance can’t capture these measurements on their own.
Note: For an elevation of an apartment building, scans of the shared hallway aren’t enough. Also scan inside the units and rooms that border the exterior walls being drawn.
Capturing Exterior Elevations: How to Capture Scans for Exterior Elevations
Step 2: Capture the exterior horizontal scans
Walk a complete loop around the building and capture:
  • 1 scan every 10–20 ft (3–6 m), about 5 ft (1.5 m) from the building face.
  • 1 scan at every building corner, about 5 ft (1.5 m) from the corner.
  • 1 scan centered on each window, about 5–10 ft (1.5–3 m) from the building face.
Where possible, also capture 3 scans on each building face, in a straight line at about 90° to the building exterior:
  • 10 ft (3 m) from the building
  • 20 ft (6 m) from the building
  • 30 ft (9 m) from the building
Step 3: Capture the vertical scan sequence
Capture the interior and exterior vertical scans as one continuous sequence through the property. Start at the exterior front of the building.
  1. Capture the required exterior vertical scans at the front of the building.
  2. Enter the building and capture the required interior vertical scans.
  3. Continue through the interior in a straight line, following the numbered scan points shown in the diagram.
  4. Capture the required vertical scans at the rear of the property.
  5. Exit through the rear door and capture the required exterior vertical scans.
Watch the video below for recommended camera positioning and techniques for capturing these vertical scans.
Q: Do I need interior scans if I only want an Exterior Elevation?
A: Yes. Interior scans of the areas bordering the exterior walls are required for accurate elevation drawings. Exterior scans alone, or interior scans of shared spaces like hallways, won’t capture the measurements needed.
Q: Can I get elevations for a building taller than 2 storeys?
A: Usually not. Due to technical limitations, elevation drawings are typically limited to a maximum height of 2 storeys.
Q: Which package do I need to order Exterior Elevations?
A: The iGuide Premium base package. The Exterior Elevations add-on requires it.
Q: Do I need vertical scans outside as well as inside?
A: Yes. Exterior Elevations require both interior and exterior vertical scans, captured as one continuous sequence. See Step 3 above.
