The PLANIX Pro saves project data to a USB flash drive, so most data problems come from the drive itself: its format, how full it is, or how it was removed. This article covers USB drive best practices and how to fix common drive errors.
USB Flash Drive Best Practices
- Use a recommended drive such as the SanDisk Ultra Flair 16 GB.
- Don't fill the drive beyond 75%. Past that point, write speeds drop by 50%.
- Always copy projects to your computer before opening them in Stitch. Never run a project directly from the USB drive.
- Eject safely using the Safe Eject button in Survey Settings, or power off the camera before removing the drive.
- Format USB drives as FAT (MSDOS), FAT16, or FAT32 with a single partition.
Fixing USB Drive Errors
- "NO DISK" error: Reinsert the drive. If the error continues, the drive may be damaged — replace it.
- Corrupted images: Usually caused by removing the drive while the camera was on. In Stitch, right-click any affected pano and choose Reload to recreate it.
If data issues continue, open a ticket and attach your logs — see Submitting PLANIX Pro Logs for Support.
