The PLANIX Pro is iGuide's professional-grade 3D capture system that combines a Ricoh THETA Z1 360° camera with built-in LiDAR to produce accurate floor plans and immersive virtual tours. It is purpose-built for real estate, insurance, and design professionals who need reliable, high-precision spatial data.
This system delivers measurement accuracy within ±1 cm at ranges up to 40 metres, paired with 26-megapixel imagery, giving operators a complete tool for capturing properties efficiently and producing polished, client-ready iGuide projects.
- What is included with a PLANIX Pro camera unit
- Mounting the System
- PLANIX Core
- PLANIX Pro Camera Manual & Specs
- Important Notes
- FAQs
What's Included with a PLANIX Pro Unit
- iGuide PLANIX Pro camera system Custom-molded carrying case
- Swappable system battery
- USB drive
- Case strap
- Charging adapter
- Lens cap for the Ricoh THETA Z1
Mounting the System
- Mount the system on a Manfrotto QR plate, or
- Mount the system using an Arca Swiss plate.
PLANIX Core
PLANIX Pro Camera Unit Manual & Specs
- Download the PLANIX Pro manual here:
| iGuide PLANIX | |
Lidar Measurement Range |
Up to 40m (approx. 131′) |
| Lidar Measurement Uncertainty | +/- 1cm (approx. 0.4″) up to max range (typical, based on at least 60cm (approx. 23.6″) wide wall segment) |
| Lidar Field of View | 360 degrees |
| Type of Lidar | Time of flight |
| 360° Camera | Ricoh THETA Z1 |
| Output Resolution | 26 Megapixels |
| WIFI | 802.11 2.4GHz/5GHz Access Point |
| Software | Planitar web app in a web browser over Wi-Fi from any device |
| System Battery | 7.5V 6.9Ah/47.7Wh Li-Ion, user-replaceable |
| System Power Supply | Input – 100-240VAC, 50-60Hz, 1.0A; Output – 12VDC, 3.3A |
| System Battery Performance | 7 hours of typical operation |
| System Unit Weight | 980g (2.16lbs) |
| System Unit Dimensions | W: 11cm (4.3″) x D: 11cm (4.3″) x H: 34cm (13.4″) |
| Shipping weight (with carrying case, without packaging) | 3.6 kg (8 lbs) |
| Carrying Case Dimensions | W: 39cm (15.4″) x D: 29cm (11.2″) x H: 17cm (6.7″) |
| Tripod Mounting Thread | 1/4-20 |
| Operating Temperature Range | 0-40 degrees C (32-104 degrees F) |
| Storage Temperature Range | -20-50 degrees C (-4-122 degrees F) |
| Relative Humidity | 0-90% |
- Please make sure you charge the system before your first time using the PLANIX Pro camera.
Q: What should I do if I notice my camera is damaged?
A: Please either call or create a support ticket to the Product Support team. Please be as descriptive of the damage. The Support team will work on a solution for your situation that may include sending in the unit for repairs, or shipping a loaner system out.
Q: How will I know when the PLANIX Pro battery is running low?
A: The battery icon in Survey changes as the battery runs down:
- Below 20%: The battery icon turns red and shows one bar.
- Below 10%: No bars, and the icon blinks red.
- Below 1%: A notice says the camera will shut down in 10 seconds, and then it shuts down automatically.
When the icon turns red, finish your current scan and charge or swap the battery before continuing.
