The Ricoh Theta Z1 firmware must be updated separately from the PLANIX system to ensure optimal performance and compatibility with iGuide PLANIX cameras. The update is completed using the Ricoh Theta app on a smart device, which connects directly to the camera over Wi-Fi.
This process keeps the 360° camera running smoothly within the iGuide workflow, helping operators avoid compatibility issues, maintain image quality, and stay aligned with the latest improvements released by Ricoh for the Theta Z1.
- Download the Ricoh Theta app on your smart device (iOS or Android)
- IOS: https://apps.apple.com/us/app/ricoh360-theta-capture-app/id6446307957
- Android: https://play.google.com/store/apps/details?id=com.ricoh360.mobile
- Have your Theta Z1 camera nearby and ready to power on
- Enable Airplane Mode with Wi-Fi on to prevent cellular interference during the update
Steps to Update the Theta Z1 Firmware
- Power on the Theta Z1 and single-press the Wi-Fi button until the Wi-Fi symbol begins flashing
Note: from this point on you may need to switch between Wi-Fi connections for Internet connectivity and Z1 communication. During this process, airplane mode is recommended (with Wi-Fi on) as your cellular connection can interfere with the process.
- Open the Theta app and log in (or create an account if it's your first time)
- Tap the THETA section at the bottom of the screen. If your camera is already registered, skip to Step 7
- Tap Register RICOH THETA, select RICOH THETA Z1, and follow the prompt to enable Wi-Fi and Bluetooth on the camera
- Open your phone's Wi-Fi settings, connect to the camera's network (named THETAYN...), and enter the numbers shown as the password
- Return to the app, tap Next, then tap Show registered RICOH THETA.
- In the THETA section, scroll to General and tap Update Firmware
- If an update is available, tap Update on both prompts
- When prompted, switch your phone's Wi-Fi back to a regular internet connection (not the camera's Wi-Fi)
- Return to the app and tap Download. Do not switch screens during the download or it will restart
- Once the download finishes, tap OK, reconnect to the camera's Wi-Fi, then tap Transferring Files. The camera will reboot during this step — do not turn off the camera or phone
- When the transfer is complete, tap OK, then Quit the Firmware Update. The camera can now be powered off.
- Cellular data can interfere with the update — use Airplane Mode with Wi-Fi enabled throughout
- Check out Ricoh's Step by Step guide to updating firmware below:
