PLANIX Pro Hardware Troubleshooting
This article covers physical PLANIX Pro fixes you can do in the field: seating the battery, factory resetting the system, installing a PLANIX Core or replacement Theta Z1 camera, aligning the 360° camera, and calibrating the compass.
Inserting the PLANIX Pro's Battery
  1. Press the button on the battery to confirm it has charge.
  2. Line the battery up with the pins, with the pull tab facing the outside of the PLANIX Pro.
  3. Press the battery down while gently rocking it side to side.
  4. Confirm the battery sits fully below the side tabs.
PLANIX Pro Hardware Troubleshooting: Inserting the PLANIX Pro's Battery
Factory Resetting the PLANIX Pro
  1. Power on the PLANIX Pro and wait until the status indicator stops blinking.
  2. Use a paperclip or SIM tool to hold the reset button (next to the charging port) for 3 seconds.
  3. Release once the status and battery indicators turn off.
Note: A factory reset clears all user settings. The Wi-Fi password resets to the camera's serial number.
PLANIX Pro Hardware Troubleshooting: Factory Resetting the PLANIX Pro
Setting Up a PLANIX Core / New Theta Z1 Camera
  1. Remove the four M3 screws from the 360° camera mount using a #1 Phillips screwdriver.
  2. Attach the Theta Z1 to the mount using the provided black ¼" thumb screw.
  3. Connect the USB-C cable to the Theta Z1 (it only engages in one orientation).
  4. Attach the camera mount to the system, routing the USB cable around the plastic screw boss and between it and the adjacent flat fin.
  5. Reinstall the four M3 screws without overtightening. Power on the system, connect via Wi-Fi, and run lens alignment from Survey Settings (see below).
Aligning the 360° Camera
  1. Open the Survey interface and go to Settings.
  2. Run the lens-to-lidar alignment procedure any time the Theta Z1 has been removed, replaced, or reinstalled.
  3. Check alignment in Measure Mode 1: a corner on the floor plan should line up with the same corner in the 360° image.
Note: User-supplied Z1 cameras don't have Planitar's factory lens calibration.
PLANIX Pro Hardware Troubleshooting: Aligning the 360° Camera
Compass Calibration
The PLANIX Pro calibrates through the Survey app using a guided rotation.
  1. Open the Survey app on the PLANIX Pro.
  2. Go to the Settings menu and select Calibrate Compass.
  3. Follow the on-screen instructions. Slowly rotate the camera around three roughly perpendicular axes for about 15 to 20 seconds.
  4. If the procedure times out after 60 seconds, start it again.
For more detail, see PLANIX Camera Compass Calibration.
