iGuide Square Footage Disputes
This article helps you understand why iGuide square footage can differ from other sources, such as tax records or a builder’s floor plan. Knowing how each source measures a property helps you interpret discrepancies and decide whether a review is needed.
Understanding iGuide Measurements
Why Measurements Differ Between Sources
Different measurement methods produce different totals. Methods mainly differ in which spaces are excluded from the reported square footage. They also differ in how they handle features such as sloped attic ceilings or shared demising walls.
The iGuide method follows the Alberta RMS, currently the most comprehensive standard in North America. Alberta RMS is based on ANSI Z765-2013 for single-family houses. It extends that standard to condos and apartments in multi-family residential buildings. It was created because municipal tax record values have no prescribed standard, which makes cross-property comparisons unreliable.
Comparing Measurements and Uncertainty
Every real measurement has some uncertainty. The iGuide camera measures wall distances to within 1 cm.
For a typical house, stacking several rooms can add up to 5 cm of uncertainty across the whole house. That is about 0.5% for distance measurements at that floor size. The resulting square footage uncertainty is about 1%, double the distance uncertainty.
When you compare measurements:
  1. Ignore differences smaller than 1% (about 25 sq ft for a 2,500 sq ft house). These are below measurement noise.
  2. If the difference is more than 1%, check the other source’s uncertainty and combine it with iGuide’s.
  3. Calculate combined uncertainty as the square root of the sum of squared uncertainties. For example, 1% and 3% combine to 3.16%.
  4. If the other source has no stated uncertainty, treat iGuide as the most accurate measurement.
Note: Alberta RMS and ANSI both allow a maximum measurement uncertainty of 2%. iGuide technology meets and exceeds this requirement.
Why iGuide Differs from Tax Records
Tax record square footage is not considered accurate unless it has been independently verified. It is estimated from the outside of the structure. The estimator often hasn’t entered the building. They may not know about areas that are excluded from interior square footage, such as areas open to below, cold rooms or differences between floor footprints.
Why iGuide Differs from a Builder’s Floor Plan
A builder’s floor plan shows what the builder intended to build (build-as). Changes often happen during construction, so the finished home may differ from the original blueprints. iGuide floor plans show what was actually built (as-built), which is what a real estate agent is selling.
After construction, we recommend having an independent company verify room dimensions and total square footage. These may differ significantly from the builder’s plans. Builders use floor plans to sell unbuilt homes and usually include disclaimers for deviations in the sales contract.
Reviewing iGuide Numbers for Accuracy
Our drafting team checks every iGuide through a Quality Assurance process before it is uploaded to the iGuide Portal. This confirms all floors are drafted correctly. If you suspect a discrepancy:
  • Use the on-screen measuring tool in the iGuide to measure anywhere on the floor plan.
  • Check the arrows in the PDF floor plans. They show each room’s dimensions and where measurements start and end.
  • Check the colour coding. Coloured areas are included in the total square footage, and white areas are excluded.
  • Tell us exactly where you believe the discrepancy is, so our drafting team can investigate.
Requests Outside the iGuide Drafting Standard
Our drafting team drafts every property to the iGuide Drafting Standard. Photographers can leave a note in the uploaded data to make a special request. You can also make a request after an iGuide is completed.
Important: If we fulfil a special request that goes against the iGuide Drafting Standard, the requester assumes responsibility if the measurements are later questioned. Charges may apply depending on the request.
  • All measurements have uncertainty. Differences below 1% are insignificant. Larger differences require knowing the other method’s margin of error.
  • Different standards lead to misleading comparisons. Tax records and other measurements may not follow a consistent or recognised standard. iGuide follows ANSI and Alberta RMS for consistent results.
Square footage doesn’t match tax records: Tax records are estimated from outside the building and often include areas iGuide excludes. See Why iGuide Differs from Tax Records above.
Square footage doesn’t match the builder’s floor plan: Builder plans show what was intended, not what was built. See Why iGuide Differs from a Builder’s Floor Plan above.
A room looks smaller or missing from the total: Check whether the room is shown in white on the floor plan. White areas are excluded from the total square footage.
You think a measurement is wrong: Use the on-screen measuring tool and the PDF floor plan arrows to check it. If the issue continues, please submit a support ticket with details of where you see the discrepancy.
Q: Why is my square footage different from another source?
A: Usually because the sources use different measurement standards or have unknown margins of error. iGuide’s margin of error is about 1%, which makes it a reliable benchmark.
Q: How accurate is iGuide?
A: iGuide square footage is accurate to about 1%. The camera measures wall distances to within 1 cm.
Q: Does iGuide meet ANSI and Alberta RMS requirements?
A: Yes. Both standards allow a maximum measurement uncertainty of 2%, and iGuide meets and exceeds this.
Q: Why are some rooms shown in white on the floor plan?
A: White areas are excluded from the reported square footage. This can be because the space is unfinished, has insufficient ceiling height or is open to below.
Q: What should I include when reporting a possible discrepancy?
A: Tell us exactly where you believe the discrepancy is. This helps our drafting team investigate.
Q: Can I ask for my iGuide to be drafted differently from the standard?
A: Yes. Photographers can leave a note in the uploaded data, or you can make a request after the iGuide is completed. The requester assumes responsibility for non-standard measurements, and charges may apply.
