iGuide Custom RMS Compliance Tools
Customise your iGuide PDF floor plans and iGuide Reports to support compliance with the Alberta Residential Measurement Standard (RMS). iGuide follows RMS, adapted from ANSI Z765-2013. You can add measurement diagrams, surveyor confirmations or notes about total areas. For the full standard, see the Alberta RMS RE-REP 2017 eBook.
This article explains how to set up each tool, either as a default in your iGuide Defaults or for a specific iGuide.
How to Customise PDFs and Reports for RMS Compliance
Note: Each tool can be set in iGuide Defaults or in a specific iGuide. Use the specific iGuide path when a property needs different settings from your defaults.
Step 1: Append measurement diagrams to PDFs
In iGuide Defaults:
  1. Go to User Settings > iGuide Defaults > iGuide Viewer > Other Options.
  2. Select Append Measurement Diagrams to PDF (Alberta).
  3. Click Save.
In a specific iGuide:
  1. Go to Search My iGuides > Edit > Options.
  3. Click Save.
iGuide Custom RMS Compliance Tools: How to Customise PDFs and Reports for RMS Compliance
Step 2: Add custom text to PDF reports
Use custom text to add information such as surveyor confirmations or area instructions to your PDF reports.
In iGuide Defaults:
  1. Go to User Settings > iGuide Defaults > iGuide Viewer > Default PDF Custom Text.
  2. Enter your text.
  3. Click Save.
  1. Go to Search My iGuides > Edit > Custom Text for PDF.
  2. Enter your text.
  3. Click Save.
Step 3: Insert additional notes in the iGuide Report
Use additional notes to clarify total areas and measurement responsibilities.
In iGuide Defaults:
  1. Go to User Settings > iGuide Defaults > iGuide Report > Default Report Notes.
  2. Enter your notes.
  3. Click Save.
  1. Go to Search My iGuides > iGuide Report > Additional Notes.
  3. Click Send.
Important: Requests that go against the iGuide Drafting Standard are handled separately. If one is fulfilled, the requester assumes responsibility if the measurements are later brought into question, and charges may apply.
Q: How do I add a surveyor confirmation to my PDF floor plans?
A: Use Custom Text for PDF. Set it as a default under User Settings > iGuide Defaults > iGuide Viewer > Default PDF Custom Text, or for one iGuide under Search My iGuides > Edit > Custom Text for PDF.
Q: Are iGuide measurements BOMA or SIOR certified?
A: No. We only draft within the standards of ANSI or RECA RMS. You can derive area measurements from the floor plans or DXF files for other measurement standards.
