Merging Projects & Floors in Stitch
Stitch lets you organize scans into floors and buildings, and combine scans from separate projects into one iGuide. This article covers merging projects, creating floors, moving panos between floors, and adding a new building.
Merge Projects
  1. Only merge scans captured with the same iGuide camera serial number.
  2. Use Windows Explorer or Mac Finder to move scan or floor folders between projects.
  3. Keep the folder hierarchy: scan folders inside floor folders, and floor folders inside the main project folder.
  4. Rename folders to resolve any naming conflicts.
Important: Don't merge projects from different camera systems (for example, R1 and PLANIX Pro). This may corrupt your data.
Create a New Floor
  1. Right-click the building where the floor should be added.
  2. Select Add Floor.
  3. Click the floor name to rename it.
Move Panos Between Floors
  1. Hold Shift to select a range of panos, or Ctrl/Cmd to select multiple individual panos.
  2. Drag and drop the selected panos into the desired floor.
Add a New Building
Each building shows its own area totals in the final iGuide.
  1. Right-click the project name in Stitch.
  2. Select Add Building.
  3. Drag and drop floors or scans into the new building.
