Presets let you save the image adjustments you make regularly, like brightness or contrast, and apply them consistently across panoramas. This article covers saving, applying, and auto-importing presets, plus tips for improving white balance in Stitch.
- How Presets Work
- Saving Presets
- Applying Presets
- Auto-Importing Presets
- Tips on Improving Image Quality
How Presets Work
Presets are applied on top of Planitar's Auto Color adjustments, which Stitch applies automatically by default. A preset stores only the extra adjustment you add after Auto Color, not the total value you see.
For example, if Auto Color sets brightness to +15 and you always want +10 more (for +25 total), save the preset with brightness at +10.
Note: If you've reset or changed any adjustments, click Auto Color before applying a preset. With an R1 system, image processing happens at capture, so you don't need to click Auto Color.
Saving Presets
- Click the wizard hat icon (or press A) to open image adjustments.
- Click Reset beside Equalize.
- Adjust temperature, brightness, contrast, and saturation as offsets to Planitar's Auto Color.
- Save your adjustments to one of three preset slots.
Applying Presets
- Click Auto Color first to restore Planitar's default settings (not needed for R1).
- Select your preset and click Load to apply it to the current pano.
- Use Next Pano to apply it across multiple images.
- Use Paste to All only if all panos are still on default settings.
- Open Settings (shortcut W).
- Choose a preset to apply automatically when you import new projects.
- Click Adjust Panoramas (wizard hat icon).
- Use the Eyedropper Tool to set global white balance. Try several areas to find the most natural result.
- If blue tones persist (for example, near windows), lower the Blue Slider. This affects all blue tones in the image.
