Stitch lets you control which panoramas appear in your iGuide, where the tour starts, and which extra images, like drone aerials, are included. This article covers turning panos on or off, setting the initial pano and angle, and adding user or drone panos.
Turning Panos On or Off
- Middle-click the pano in Project Explorer, or right-click the scan and choose Hide in iGuide.
- Disabled panos appear red with hollow dots on the floor plan.
Note: You can also disable panos later in the iGuide Portal after publishing.
Set the Initial Pano and Angle
The initial pano is where the 3D tour starts.
- Right-click the desired pano and select Set as initial pano.
- Click Set initial pano angle, then left-click in the pano to set the viewing direction.
- Check the visual indicators: a blue box shows the selected angle for a pano, and an orange box shows the initial pano angle.
Important: An initial pano must be set before exporting from Stitch. You can change it later in the iGuide Portal.
Add User or Drone Panos
User panos appear in the tour but don't include laser data or navigation arrows. They're often used for drone aerials and points of interest near the property.
- Right-click the floor where the pano should appear and select Add user pano.
- Choose the image to upload when prompted.
- Set the position and rotation of the pano on the floor plan.
Note: Use a 2:1 ratio image, up to 7200×3600 px. Non-panoramic images appear distorted, and incorrect ratios add black bars.
