Snapshot Mode lets you frame and capture still images directly from your 360° panoramas and add them to a property's gallery. It's the fastest way to pull listing-ready photos out of a pano without leaving the iGuide Portal.
Snapshot Mode is built for two main jobs:
- Documenting damage or other property details from a pano for an insurance claim or report
- Pulling gallery photos for an MLS listing or a social media post from a pano you've already captured
How to Use Snapshot Mode
Snapshot Mode is available from the Gallery page in the iGuide Portal.
- Open the property's gallery in the iGuide Portal.
- Choose your Field of View, and enable "Grid Mode" if desired
- Drag to reposition the framing of the pano image
- Click "Take Snapshot". A short animation confirms the still has been added to the gallery.
If a capture comes out misaligned, re-open the pano in Snapshot Mode and capture again. The original pano isn't affected.
Things to Know
- Snapshot Mode is for manual capture
- There’s no built-in HDR merge, tone mapping, or denoise. For advanced editing, download the still and use your preferred image editor
- Snapshot Mode is designed for quickly capturing and adding images directly to your iGuide gallery. This feature is intended primarily for the insurance industry
FAQ
Q: Can I batch-generate stills automatically?
No. Snapshot Mode is manual capture only.
Q: Can I edit exposure or colour from inside the tool?
To make adjustments, download the still and edit it in your preferred image editor.
Q: Will using Snapshot Mode change the original pano?
No. Captures are read-only operations against the pano. You can re-capture as many times as you like without affecting the source.
