Creating and Upgrading iGuides on the Portal
Creating an iGuide on the portal is a straightforward upload process that turns your captured project data into a published, shareable tour. The workflow involves selecting an industry, choosing a package and add-ons, entering the property address, and uploading your exported Stitch TAR file.
You can also upgrade existing iGuides or add new features—such as ESX, CAD, or 3D Model add-ons—directly from the portal after publishing.
  1. Transfer your project to a computer and export it through Stitch
  2. Confirm you are logged into the iGuide Portal
Steps to Create an iGuide
  1. Select + Create iGuide in the iGuide Portal
  2. Choose the Property Industry that matches your intended use
  3. Choose the iGuide package and add-ons that best suit your project—these can be upgraded later after publishing
  4. Enter the property address, or select Disable Property Address to use a custom name instead (this choice cannot be reverted afterwards), then click the blue Select button to continue
  5. Drag and drop the exported Stitch TAR file into the Upload Stitch Data section
  6. Fill in any advanced options you want to apply before uploading—most of these can also be customized later
  7. Click the blue Create iGuide button to begin uploading; a progress bar will appear at the bottom of the page and confirm completion at 100%
How to Upgrade or Request an Add-On for a Published iGuide
  1. Go to the iGuidePortal and click My iGuides
  2. Click the desired iGuide Click Packages & Add-ons
  3. To request an upgrade, click the appropriate option under Package Upgrade—all applicable options will be visible
  4. To request an add-on, click Edit Add-ons
  5. Select all applicable add-ons you wish to request
  6. Click Request to submit
Applicable Upgrades & Add-Ons
Starting Package & Add-ons Upgrade Packages & Add-ons
iGuide Radix Upgrades: Instant Sketch, iGuide Standard, iGuide Premium
iGuide Instant Upgrades: iGuide Standard, iGuide Premium
iGuide Instant Sketch Upgrades: GUIDE Standard, iGuide Premium
iGuide Standard
Upgrades: iGuide Premium, Advanced Drawing Package
Add-ons: Xactimate ESX, AutoCAD DWG
iGuide Premium
Upgrades: Advanced Drawing Package
Add-ons: Floorplan (DWG), Reflected Ceiling Plan (DWG), Exterior Elevations (DWG), Roof Plans (DWG), 3D Model (DWG/RVT)
iGuide Advanced Drawing Package Add-ons: Floorplan (DWG), Reflected Ceiling Plan (DWG), Exterior Elevations (DWG), Roof Plans (DWG), 3D Model (DWG/RVT)
Best Practices
  1. Always export your Stitch project to a TAR file before starting the upload to avoid mid-process delays
  2. Double-check the property address (or custom name) before clicking Select, since this choice cannot be reverted later
  3. Take advantage of post-publish flexibility—packages can be upgraded and add-ons requested at any time from the My iGuides page
