Edit View Page Introduction
The Edit View Page is the central hub for customizing a published iGuide from within the iGuide Portal. It allows you to update the title, set how the 3D tour starts, control which panos and floors are visible, adjust the compass, set expiration dates, and configure advanced display options for the viewer and PDF outputs.
This page gives you full control over how your iGuide is presented to viewers, helping you tailor each tour to suit branding, privacy, and presentation preferences before sharing it with clients or buyers.
Understanding the Edit View Page
The Edit View Page is the main location for making edits to a published iGuide. From this page you can:
  1. Customize the iGuide name
  2. Choose how the 3D tour begins
  3. Configure advanced settings
  4. Turn panos, floors, and buildings on or off
  5. Set the initial pano for the 3D tour
  6. Adjust the compass orientation
Locating the Edit View Page
To open the Edit View Page for any iGuide:
  1. Go to the "My iGuides" section of the iGuide Portal
  2. Find the iGuide you wish to edit
  3. Press the "Edit" button to open the Edit View Page
Edit View Page Introduction: Locating the Edit View Page
Edit View Page Definitions
Edit View Page Introduction: Edit View Page Definitions
This section explains each of the main fields available on the Edit View Page.
  • Title - displayed at the top of the iGuide to identify the property; defaults to the property address when empty
  • Expiration Date - sets when the View becomes locked and inaccessible via the public link
  • Start Options - determines how the iGuide launches (see breakdown below)
  • Units - sets the default unit of measurement
  • Viewer Color Scheme - chooses the colour scheme for room types in the iGuide Viewer
  • PDF Color Scheme - chooses the colour scheme for room types in the PDF and/or Viewer
  • Compass Angle - adjusts compass orientation when the default is incorrect or missing
  • Property Description - an optional description shown on the Details tab in the Viewer
  • Custom Text for PDF - text shown at the bottom of the PDF Floor Plans Property Details section, augmented with agent or brokerage details when a banner is used
  • Embedded Video - URL of a YouTube or Vimeo video to feature within the iGuide (branded or unbranded)
  • Lot Size (Site Plan add-on only) - editable field for operators to input or correct lot size when third-party data is unavailable
  • Protection - lets you add or remove people permitted to view the iGuide; managers and editors always retain access
Start Options Explained
The available start modes include:
  1. 3D Tour - starts in standard Tour mode
  2. 3D Tour: Autoplay - automatically guides viewers through panos in sequence without user input
  3. Gallery - launches the Still Image Gallery
  4. Gallery - Slideshow - launches the Gallery in slideshow mode
  5. Video - launches external Video mode
  6. Video - Autoplay - launches and starts the video automatically
  7. Video - Autoplay > 3D Tour - plays the video, then opens the 3D Tour
  8. Video - Autoplay > 3D Tour - Autoplay - plays the video, then opens the 3D Tour in autoplay
Note: Autoplay sequence follows the order panos were submitted via Stitch, so arrange them accordingly before uploading. Video options support YouTube and Vimeo.
Options Breakdown
Edit View Page Introduction: Options Breakdown
The Options section gives you granular control over what appears in your iGuide Viewer, PDF Floor Plans, and Reports.
  • Display and visibility options:
  • Hide building/floor areas - removes building and floor areas from the Viewer, PDF Floor Plans, and Report
  • Hide room areas - removes room areas across all outputs
  • Hide room dimensions - removes room dimensions across all outputs
  • Hide Total Interior Area when Exterior Area is Available - hides total interior area when exterior area is present
  • Hide Premium iGuide objects in 3D Tour - hides fixtures and appliances in the Viewer (still visible on PDF)
  • Hide PDF floor plans - removes the PDF download option from the Viewer and Report
  • Hide on-screen measure feature - hides the ruler icon used for on-screen measurements
  • Hide Map (always) - removes the Nearby map tab on branded and unbranded iGuides
  • Hide Map (unbranded only) - removes the Nearby map tab on unbranded iGuides only
Tour behaviour and interaction options:
  1. Show Pano Branding Image in the unbranded tour - displays the pano branding image in unbranded tours
  2. Disable 3D Tour Autoplay - turns off autoplay on the 3D Tour
  3. Mute autoplay/slideshow music by default - silences the default background music
  4. Show help message on start - displays basic navigation instructions when the iGuide loads
  5. Disable VR (if available) - hides the VR icon when VR is available
  6. Disable Advanced Measurements (if available) - turns off the advanced measurement feature
  7. Disable Tag List (if available) - hides the list of tags from the iGuide
Reporting and presentation options:
  1. Include below grade in Total Area - adds below-grade floors to the total area reported across all outputs
  2. Append Measurement Diagrams to PDF (Alberta) - includes a separate PDF set with exterior wall measurements
  3. Force branded iGuide only - disables the unbranded link in the iGuide Report
  4. Zoom Floor Plan to Walls - fits the floorplan to the viewer window
  5. Always Report Washrooms/Bathrooms in Property Details - displays all washroom dimensions in the Details tab
  6. Show Initial Banner Drop Animation - enables the banner drop animation when the iGuide first loads
3D Tour Editor
Edit View Page Introduction: 3D Tour Editor
The 3D Tour Editor lets you fine-tune the structure and presentation of your tour. From here you can:
  1. Change labels
  2. Set the Initial Pano
  3. Modify wall thickness
  4. Turn panos on or off
  5. Turn floors on or off
  6. Create custom labels
  7. Customize which room measurements are viewable
  8. Choose which rooms are included or excluded
Q: How come my edits did not save?
A: When changing anything in the Edit View Page, make sure to press the "Save" button at the bottom of the screen.
