Scanning Best Practices
iGuide Scanning Best Practices are a set of guidelines designed to help operators run efficient, high-quality shooting sessions on site. They cover camera placement, movement patterns and capture techniques that ensure accurate lidar data and a smooth post-capture workflow.
Following these practices produces cleaner wall data, faster processing and a more polished final iGuide, giving viewers an accurate representation of the property's layout once published.
What are Scanning Best Practices?
Top Priorities
  1. Maintain line of sight — every shot must be visible from the previous shot to prevent alignment issues.
  2. Start at the front door for a smooth transition between interior and exterior shots.
  3. Keep the tripod at roughly 4.5 feet (130–140 cm) from the floor.
  4. Remove clutter so lidar captures clean wall data.
Additional Best Practices
  1. Closet doors — capture one shot with the door closed and one with it open; the open shot can be hidden later but aids drafting.
  2. Tripod adjustments — temporarily change height in tricky areas so lidar hits walls correctly, then return to the original height.
  3. Larger spaces — plan a predictable route, such as following the room's perimeter first and then filling the middle using a circular or zig-zag pattern.
  4. Exterior shots — take closer shots and stay near exterior walls, since lidar has fewer surfaces to register outdoors.
Q: Should I move clothes in a closet before taking a shot inside?
A: You definitely should move the clothes around to make sure the lidar can hit all the walls to ensure accuracy in measurements.
Q: What should be the normal height for the tripod?
A: Suggested height is approximately 4.5 feet (130-140 cm) from the floor.
