Capturing your first property with iGuide involves a few core steps: walking the site, setting up your camera and tripod, connecting the camera to your smart device through the PLANIX App, and scanning each room and floor in sequence.
This guide covers the essentials you need to scan accurately and efficiently — from equipment setup to in-app workflow — so you can confidently complete your first project.
- Initial Site Walkthrough
- Getting Ready to Capture
- Setting Up the Camera and Tripod
- Connecting the Camera to Your Smart Device
- Using the Planix App
- Important Notes
- Level the tripod's ball head mount
- Attach the quick-release (QR) plate to the PLANIX camera, then secure it to the ball head
- Set the lens height to 4.5 ft (130–140 cm) for optimal accuracy
- Adjust height only to clear obstacles or improve lidar coverage — verify in Survey
- Return to 4.5 ft after each adjustment for consistency.
- Use the on-camera level and adjust until both indicators are green.
PLANIX R1
1. Download the App
- Get the iGuide PLANIX App (iOS/Android) and finish onboarding
- Allow local network access
2. Add a New Device
- Tap “New Device” in the top-right corner
- Grant location access when prompted
3. Power On the PLANIX R1
- Press and hold the power button for 3 seconds.
- Wait ~20 seconds for the lidar to start spinning.
4. Scan the QR Code
- Tap “Next” and scan the QR code on the PLANIX R1 screen.
- The app will request camera access.
5. Join the Wi-Fi Network
- When prompted, connect to the PLANIX Wi-Fi (ends in .OSC).
- Once connected, you're ready to scan.
PLANIX Pro
1. Download the App
- Download the iGuide PLANIX App from the App Store (IOS) or Google Play Store (Android).
- Complete the onboarding screens.
2. Add a New Device
- Tap “New Device” in the top-right corner.
- Allow location access and tap “Turn On Camera.”
3. Power On the PLANIX Pro
- Wait ~20 seconds until the lidar spins.
4. Scan the QR Code or Connect Manually
- If available, scan the QR code in your Quick Start Guide.
- If not, Connect Manually
- Tap “Open Settings” and go to Wi-Fi.
- Select the camera network (e.g., planix-XXXXXX).
- Enter the Wi-Fi password (on the camera’s base label).
- Return to the app to continue.
Using the PLANIX App
Create a New Project
Open the app and from the "Devices" list click on your camera
A new Project will open
Enter the property name and details
Scan
- From the hamburger menu, tap Survey, then the center capture button
- The camera collects panoramic data; each scan point appears on screen
Add a New Floor
At a new level, click the hamburger menu, tap Floor
Name it by typing a name (e.g., “Second Floor”) or picking one from the list, such as Basement, Exterior, Perimeter, Roof, Garage or Shed.
Continue scanning. Repeat per level.
Battery: When the battery icon turns red (below 20%), swap or charge the battery. Below 1%, the camera shuts down automatically after 10 seconds.
- Tripod height: Always return to 4.5 ft (130–140 cm) after adjustments
- Lidar check: Use Survey view to confirm lidar reads walls correctly, especially near large furniture or open spaces
- Wi-Fi required: The app must stay connected to the camera's Wi-Fi
- Permissions: Local network (device), Location (Wi-Fi setup), Camera (QR scanning)
- Manual floor creation: New floors must be named manually before scanning — there is no auto-detection
Q: Do I need internet access to scan a property?
A: No. The PLANIX connects to your device via local Wi-Fi. No internet is required during scanning. Internet connection is required for uploading to the portal.
Q: Can I adjust tripod height during scanning?
A: Yes, but only for obstacle avoidance or tight spaces. Return to the standard height afterward for consistency.
Q: What happens if I scan out of order or miss a room?
A: You can return and scan the missed area. Just ensure good line of sight with existing scan points for accurate alignment.
Q: Can I scan multiple floors in one project?
A: Yes. Tap Floor in the app, name the new level, and continue scanning.
Q: Are all devices compatible with the PLANIX App?
A: The app supports most iOS and Android devices. Ensure your OS is up-to-date for best results.
