Offline Project Editing Within the PLANIX App
The Offline Editing feature in the PLANIX app allows Operators to make adjustments to their iGuide projects without being connected to a camera. Edits include aligning or deleting scans, managing tags, modifying floor structure, and renaming the project — all from the Projects section of the app.
This feature gives Operators the flexibility to keep projects organized between shoots, refine work in progress, and prepare data for upload, helping streamline the iGuide workflow without needing live access to the PLANIX R1 or PLANIX Pro camera.
What Edits Can Be Made Offline
  1. Align, edit, or delete scans — adjust alignment, refine placement, or remove scans no longer needed
  2. Create, edit, or delete tags — add new identifiers, update existing ones, or remove outdated tags
  3. Add, edit, or delete floors — manage your project's floor structure without a live camera connection
  4. Edit project names — rename projects to reflect clearer conventions, client info, or revision numbers
How to Access Offline Editing
  1. Open the PLANIX app on the mobile device where the project was originally captured
  2. Tap Projects at the bottom of the screen
  3. Tap the three dots beside the project you want to edit Select
  4. Edit (Offline mode) Make your applicable edits
  • Edits are automatically saved to the project once completed
  • New scans cannot be added in offline mode — a live camera connection is required to capture additional scans
