iGuide for Facility Management
iGuide helps Facility Managers capture, document, and manage building data through accurate floor plans and immersive 3D tours. It enables quick interior scans, precise measurements, and shareable virtual environments, supporting space planning, maintenance, and stakeholder collaboration from a single digital platform.
This system provides a clear and detailed view of facility conditions, helping managers coordinate inspections, plan layouts, and communicate with contractors, designers, and regulators without relying on repeated site visits.
Key Use Cases
A brief look at how Facility Managers apply iGuide across building operations:
  1. Visual inspections — identify equipment, access needs, and conditions remotely
  2. Space planning — measure wall areas, place equipment, and plan layouts
  3. Maintenance and repairs — document facility conditions for cost analysis and planning
  4. Stakeholder collaboration — share data with contractors, designers, and regulators
  5. Tenant marketing — provide virtual tours for space evaluation by potential tenants
  6. Construction monitoring — track progress and ensure safety standards
Recommended Packages and Add-ons
The following packages and add-ons are recommended for facility management workflows:
Key details to keep in mind when using iGuide for facility management:
  1. The Default View uses a unique URL that does not include the property address
  2. The Default View is not indexed by search engines, so address-based searches will not surface the 3D tour link
  3. The Default View is not discoverable on the iGuide Map
  4. RMS is the measurement standard for Canada and other regions
  5. ANSI is the measurement standard for the United States
  6. Floor plans can be exported in multiple formats, including PDF, DXF, DWG, JPG, and SVG
  7. Real-time tagging supports detailed documentation but requires proper setup
  8. Integration with CAD and space planning software is supported, though formatting adjustments may be needed
Q: Can I use iGuide data in CAD software?
A: Yes, floor plans can be exported in compatible formats.
Q: Is real-time tagging available?
A: Yes, tags can include text and images.
Q: Can iGuide reduce site visits?
A: Absolutely—virtual walkthroughs and measurements minimize the need for physical inspections.
Q: Is it suitable for large facilities?
A: Yes, iGuide is optimized for complex and expansive spaces.
